QUOTE(Highland @ Jul 1 2022, 03:11 PM)
So I thought I'd update in case anyone else runs into the same issue and maybe to get some guidance of my stock distributer situation.
Prior to the 123 distributor install I was using a stock distributor with Pertronix 1. Car started cold no problem with throttle closed. I got pretty consistent hot starts by cycling the gas pedal 5 times (firing TPS) then starting with throttle full open. To get the car running right I had a ~650 ohm resistor inline with the CHT.
As the thread has documented that setup did not work with the 123 distributor.
Currently the car starts hot or cold with gas pedal all the way down prior to ignition on (to avoid firing the TPS). Runs great. Steady idle. Timing set at 8 at idle and 27 at 3500. I only have an O2 sensor on #3 exhaust pipe, but it reads around 13 at idle and at 3000 rpm 5th gear cruise 14. The 123 has really improved engine performance and is running well now.
I did a lot of things, but the ones below seem to make a difference:
- Re-gapped the spark plugs to 0.7 mm. The gaps were all a little large. All the plugs look about the same as the one shown. This plug is post trying to tune with the 123 distributor. I'm guessing that's the reason for the rich mixture carbon build-up.
Click to view attachment- Removed the 650 ohm inline CHT resistor.
- Richened the MPS by about a quarter turn of the inner screw.
So why such a big difference with my old dizzy? I thought perhaps my old dizzy had a weak spark, but wouldn't I need a leaner mixture to light off? Was my old dizzy missing allowing a longer coil dwell time and stronger spark? Or should I just leave it a mystery and tuning an art.
Side question. Do most of you torque spark plugs to 25 ft-lb with copper paste or should it be less with the copper paste?
Book some time on a Sun Distributor machine, I understand Jay Leno has one.
You’ll probably find that you’re original distributor has many issues, ie leaking or wrong vacuum can, sticking points plate, missing circlip, worn shaft, spacers and fiber washer.
All of these contribute to distributor problems.
You removed the resister (which added fuel) and than you made the MPS run richer, 6 of one half dozen of another.
I don’t use anything on the plug threads, thread compounds create connection issues, I only pull them when the engine is cold, I usually just feel for the gasket crush, when installing, hey the original tool for the plugs was a plug shaped tube and the jack bar for leverage.
