QUOTE(malcolm2 @ Jun 5 2022, 12:35 PM)
QUOTE(Dr Evil @ Jun 5 2022, 11:04 AM)
Tooth from a slider. I find them from time to time. There are a few schools of thought on this one, and its up to you to decide.
1- you did something, that's why it broke, it works fine so you can drive it. Flush trans, no further parts, probably OK. No 100% guarantees in life.
2- you did something, that's why it broke, it works fine BUT you don't know if there are more parts that could get tossed around/part it came from may fail. Pull the stack and check/repair.
3- you did NOTHING, WTF?! Where did this come from!? Pull the stack, assess and repair.
Im typically for 2 and 3.
I am sure it was
something I did. I have put every one of the 53,000 miles on this car.
Like I said, I remember at least 2 improper shifts into 2nd and one was more memorable.....
I will study-up on pulling the stack idea. Sounds easy enough.
Thanks to all for chiming in.... I will update as I make progress. This is one of Dr Evil'z babies.
How do you flush the tranz? As I mentioned in the OP, I did drain the old gear oil and replace it yesterday. Put about 5 miles on it for a test drive and that is it.
Just to confirm, I was reading up on RATWELL and he Highly recommends the hard to find and expensive GL-4 gear oil.
Ignore the GL4 rec. Its in the specs from factory to put in GL5, even though "it attacks yellow metals" which it really just stains them. They are fine. I use cheap 80w90 GL5 and change every year, or 9kmi.
Here are the basics of pulling stack. When pulled, you can flush the box out and assure no bits are there. Check 2nd, bet you find the missing tooth. You will need to measure gasket thickness and then can replace with new when reassemble. Replaced every gasket you disturb. I have plenty of spares of things so assume tail cone (may be limited supply here, but I believe 914Rubber sells them for cheap), intermediate plate (several depending on total thickness), likely O ring at shifter (I have). If you want, send me the stack and I can pull it apart, review and repair, and send it back.
