QUOTE(Rick986 @ Jun 7 2022, 09:58 AM)
Car runs great, gauges function perfectly until...
- When I use turn signals, both temp and voltage gauges "bounce" in tandem with the signals.
- When depressing the brake pedal, temp gauge goes full right (hot), voltage drops to 9
- When I turn on the headlights, temp buries full right, voltage buries full left
Suggestions??? Thanks guys....
Ground issue for sure ,just had this with my VW Corrado,tacho would read fine then with headlights etc on the rpm would read lower, pulled the fuse box and the earth was cut for the gauge cluster when it had a crappy alarm fitted,no differant with a 914 with the exception that the wiring is some what older
Make sure you have a good clean earth clamp on your battery also.
Find all your earth posts and clean them up as well as the wiring eyelets be really fussy with these points ,I cleaned up the post threads and used new bolts and washers,one of the first things I did before starting mind numbing wiring changes for 911 gauges.
Good luck you will get there.
