QUOTE(porschetub @ Jun 8 2022, 01:59 AM)
Confused what the issue your old one ? this gear is as hard as hell and hard to damage ,someone on the WTD section would most likely just about give you one with shipping paid.
IMO I would be worried about your engine guy as it appears it was removed with the wrong press and not hot enough,just saying ok ,cheers
The damage is on the other side of the gear. I guess they pried on it with something instead of using the right tools and heat, as you said.
Click to view attachmentClick to view attachmentI gave that machine shop a few simple tasks and they failed at most of them. The rest of my components have been handled by reputable professionals, even though it cost $$ to ship heavy objects across the country!
[quote name='Jake Raby' date='Jun 8 2022, 09:07 AM' post='3007306']
The dot location on the replacement leads me to believe it is a replacement made by Sebro a few years ago.
I have seen these have too large of an OD, fit too loose and create a failure years later.
I only use original, genuine gears. Thanks for conforming the diameters are the same.
[/quoteTD
Thank you both for the advice - I'll check out the WTD section to find a good, genuine replacement gear.
