Hello friends
My last post I had a intermittent rotational hard steering. I must have applied too much steering force to the rack when turning and the pinion worm gear popped out of place from the rack making an awful grinding crunch noise when turning. Thinking the root cause was the rack and pinion I purchased from eBay I replaced it. Luckily I had a spare steering rack laying around. The 2nd rack I inspected for wear and damage, freshen it up and installed it. All the u-joints are good and free from binding.
Even with the freshened up rack and good u-joints I am still having the rotational hard steering. I have loosened the u-joint bolts on top and bottom and still no remedy I am convinced the issue is with the angle of the steering shaft and u-joint position.
Note I am running a 911 front suspension with aluminum cross member. the rack does have a bump steer spacers. I can not remove the spacers due to the the steering rack will not clear due to the coolant line that run under the center undercarriage. As temporary measure the bolt to the steering rack were the only ones I had to test, they are too long so a spacer has also been added to the bottom of the mounting bolts.
My question is anybody running a 911 front suspension with aluminum crossmember and using a bump steer spacers had the same issue. Should I be using the 911 shaft that bolt on to the steering puck. I believe the 911 shaft may be shorter. can anyone confirm this? Im tempted to cut the lower shaft 1/2 inch to get me the angle on the u-joint from binding binding up. Any thoughts?
Thanks in advance.
Al
Click to view attachment Click to view attachment Click to view attachmentClick to view attachment
