Medtner3
Jun 14 2022, 10:31 AM
What is recommended to replace the original rubber matt inside the car behind the backpad mine is all cracked and filthy
alternatively should I reuse the original rubber matt is there a way to repair it?
it is split in multiple places from folding it
I was considering Dynamat , Klimat, or Noico 80 mil butyl; Amazon
Suggestions and advice needed
FlacaProductions
Jun 14 2022, 11:00 AM
disregard/deleted - my post was about the other side of the firewall.
Root_Werks
Jun 14 2022, 12:51 PM
My 914 had some sort of sticky dynomat installed. I'm eh about it and wish it wasn't there. SO much work to remove it though. Would rather have a decent stock/heavy pad.
Medtner3
Jun 14 2022, 04:29 PM
QUOTE(Root_Werks @ Jun 14 2022, 01:51 PM)
that's an interesting point I wonder if mine can be salvaged it has so many splits from being in storage
barefoot
Jun 15 2022, 07:22 AM
Clean it & patch cracks with duct tape (both sides), it's good stuff !
Jun 15 2022, 07:34 AM
Modern products work better but are more permanent. You really have to stick the pad to the metal to damp the sound.
Mikey914
Jun 18 2022, 07:31 AM
Yes it can be salvaged. Easy to put in and remove if you decide. Duct tape will do the trick.
dr914@autoatlanta.com
Jun 18 2022, 10:28 AM
we make great copies of both the tar pad behind the vinyl covered back pad as well as the engine insulator pad on the firewall in front ot the engine
