Full Version: Slippin in a 6
Markeydoo
Ok it's time for a change. I am installing a 6 with weber 40 carbs. I don't have the original fule pump so what is a good replacement? I know the pressure should be around 3.5 pounds but I dont know what else it needs like gallons per hour. I am also looking for the part number of the original pump.
Thanks
Mark
echocanyons
I hear a peirburg pump to a continuous loop circuit with a bypass regulator recirculating back to the tank is a good method
Joe Bob
Rotary pumps....Purolator, Holley etc...
Trekkor
I have been using the Holley Red low pressure pump and one-in-two-out pressure regulator since January with *zero* problems.
KT
Trekkor
KT
Markeydoo
Thanks Guys.
North Bay 914
Did you get the Throttle cable yet?
