QUOTE(Van B @ Jun 15 2022, 09:07 PM)
AFM idle circuit is just an air bypass screw. Manual says you’re looking for 2-3% CO when fully warm at idle. You are correct that the AFM trim and TB idle screw play off each other. But you shouldn’t mess with the AFM screw without a CO meter or a wide band Lambda sensor.
missed this thread.
@Van B has already linked the info mother lode.
other little detail.
you are supposed to pull out the hose from the charcoal can at the air cleaner (assuming there is a canister still there).
......for whatever reason CO on a 75 L Jet is much lower than a 74.
0.2 to 1.2% instead of 2-3% on a 74. from factory manual. measurement is before the cat in the cal models and 75 rest of USA did not have a cat. there was a test connection port on the first muffler for those cars.
as to why and how a 75 required the much lower CO i dunno. logic tells me that would be so after the cat - thats what a cat does? - but the reading is before the cat.
there was a different ECU.
since i have a 74 i have never thought further about it.
