Geezer914
Jun 25 2022, 11:53 AM
Heavily rusted bumper, the outside is fine. What is the best way to build up the heavily rusted and pitted area?
914Sixer
Jun 25 2022, 01:13 PM
Get some navel jelly and soak it. Keep repeating until clean as possible. Lots of rust preventative paints out there.
mgphoto
Jun 25 2022, 01:21 PM
Remove the rust first, wire brush on a power drill, then phosphoric acid soak till it turns black, rinse with water very well, than seal with por-15
rhodyguy
Jun 25 2022, 01:42 PM
Could it be rechromed and look decent?
BillJ
Jun 25 2022, 02:10 PM
Unlikely that it could be brought back from that heavy pitting. Or if possible not economically feasible as you can buy a new one for not too much money. Understand the motivation but as long as it looks good on outside and you take steps above you will be fine if keeping original.
rhodyguy
Jun 25 2022, 02:28 PM
Guess it depends on what the money side looks like.
930cabman
Jun 25 2022, 02:53 PM
"Build it up" as far as I know there is no such product. You can remove the rust with one of several methods, many mentioned previously
Jun 25 2022, 03:32 PM
Here’s my guess. There is so much rust that I’d be surprised if it’s not gone through the metal and is being hidden by the chrome on the other side. I think blasting the corrosion will reveal Swiss cheesed metal. Of course I’m just guessing but it would be typical.
Geezer914
Jun 25 2022, 06:09 PM
The money side looks good. It is going to be painted.
Front yard mechanic
Jun 25 2022, 08:58 PM
Throw that thing back in the surf
Costa05
Jun 26 2022, 11:00 AM
QUOTE(mgphoto @ Jun 25 2022, 02:21 PM)
I would actually do the phospho wire brush step multiple times until the rust color no longer appears when wire brushing it. This rust looks deep.
rhodyguy
Jun 26 2022, 11:14 AM
I would use a brass wheel in my drill motor. If ok, I'll post some pictures of a rough early rear I have. Paint to match the red one on the front? Look in to Mar-Hyde for a rust converter product.
nivekdodge
Feb 27 2023, 07:23 PM
sem rust sheild
r_towle
Feb 27 2023, 07:40 PM
If your plan is to paint, just sandblast it.
Standard metal prep, fill, paint after
bkrantz
Feb 27 2023, 08:29 PM
Try to poke an awl through from either side before wasting any work time. Start with the worst spot. I bet you will find all the steel is now rust.
For painted bumpers, you can treat it like any sheet metal. Cut out the bad, weld in some new, shape, and finish.
rhodyguy
Feb 28 2023, 10:27 AM
The chrome finish one I have is the early version with the sharp edges around the plate. It’s rough. Perhaps better sold as a paintable early core as is? I have few bumpers that need new homes. This is not an ad.
BillJ
Feb 28 2023, 10:45 AM
Please follow up when you go at it. Would love to see this work out for you.
maf914
Mar 1 2023, 08:40 AM
I just ran across the following video. It may help if the rust is not too serious.
https://classicmotorsports.com/video/video-..._eid=2ed9ec98ea
