QUOTE(914Sixer @ Jun 26 2022, 12:07 PM)
Found out 73 has incorrect door. Has mid year non-guard beam door. NEED 73-76 door, a black one would be optimal.
Confused on which door you are looking for as there were 3 different door types used in 73 depending on when it was built.
1. Very Early 73s used the same doors as 72 with the cable window lifts
2. Some mid period in 73 they used the later style doors with scissor lifts but no side beams.
3. Later 73 used scissor lifts and side impact beams.
I have owned 73s of each of those styles. Still have 1&3 #2 I parted out 20 years ago but kept the doors for my autox car.
If you have a mid year door and are looking for an impact beam door I would gladly trade you one. Guessing others closer to you might as well. I like to call the midyear doors "Unicorn doors" A they are the best of both early and late doors, provided you are not looking for the side impact protection (Better window lifts than the early and much lighter weight than the lates) and are also far harder to find than the other two as there were only a small number of 73 cars made with them.
