QUOTE(914Sixer @ Jun 27 2022, 05:45 PM)
All you need is some one to do your dial face. You will need two different gauges and a soldering gun. If you have a cleaned everything up, should take 10 minutes to build gauge with parts ready to go. This a 60mm gauge so you can use it in the console. NOTE the red low light is in the left position like stock gauge NOT at 1 o"clock like GT
Do you have the part number on that fuel gauge? I have one but it reads a little on the low side. So if I truly have half a tank it will show about a 1/4 tank or less.
