I had your right picture setup, with the 911 combo pressure/temp,
My plans as part of my restoration
will be to keep my silver button 911 oil combo, and integrate the fuel gauge in the lower part of the tach (à la 911 Turbo boost gauge).
Now for the console, I want to make an analog CTH in a 60mm VDO gauge housing with a silver button hand.
I also have a 60mm VDO MBZ ambient temp gauge with a silver button, and finally I need to determine what to use as a third gauge (clock, volt, A/F ratio, other...).
The goal will be for all the console gauges to be 60mm with factory look, and silver buttoned.
Slowly working on the details as to how to. The biggest challenge at this point is the CHT. I have a temperature compensated K-Type thermocouple controller/reader (thanks
@GregAmy ) and need to figure a way to use the 0-5V output to move the hand of a 60mm gauge (oil temp maybe
) and calibrate a scale to it to show the head temp in the desired range (~150 to 500F )
Of course I could send everything to North Hollywood Speedometer but that's a different budget and where would be the fun in this!
