NARP74
Jul 5 2022, 10:35 PM
Rubbing on the inside fender well on the right rear, passenger side. Rubbing on the outside fender on the left rear driver side. Showing a little heat in the paint on the left side. I may need to go to a smaller size tire in the back, they are staggered now. Can the arms be adjusted or shimmed? Seems like they are not centering the wheels in the openings. Just starting to work on a new project.
steuspeed
Jul 6 2022, 12:53 AM
What wheel tire combos are you running?
Chris914n6
Jul 6 2022, 01:19 AM
Check the camber.
Front yard mechanic
Jul 6 2022, 06:20 AM
Tires rubbing is a good thing . It means your car is running
NARP74
Jul 6 2022, 08:40 AM
Not sure which of the 2 POs installed these;
Rear is Fuchs 5 lug, 8 J 16 w/ 215 55 16
Front is Fuchs 5 lug 7 J 16 w/205 55 16 these seem fine
Camber is on my list, an alignment is in order. Need to get some shims first.
Tires rubbing is a good thing. Great comment!
StarBear
Jul 6 2022, 09:10 AM
Just got the shim pack kits from 914Rubber. Includes o-ring washers and bolt end caps!
NARP74
Jul 6 2022, 09:31 AM
QUOTE(StarBear @ Jul 6 2022, 09:10 AM)
Thanks for the tip. Douglas Adams fan?
StarBear
Jul 6 2022, 09:48 AM
QUOTE(NARP74 @ Jul 6 2022, 11:31 AM)
Yep! Good catch. in 1981 I almost bought a house with street address "42" but it had an in-ground oil tank and asbestos around the furnace. Bought "48" instead.
NARP74
Jul 6 2022, 10:11 AM
That would have been the ultimate! 48 not so much, oh well, so long and thanks for all the fish.
burton73
Jul 6 2022, 10:25 AM
QUOTE(NARP74 @ Jul 6 2022, 07:40 AM)
Up front 7s work fine but may scrape in a full turn of steering wheel when going up a driveway. You just have to go slow with that
"Rear is Fuchs 5 lug, 8 J 16 w/ 215 55 16"
Is this a 951 number or a 911 number on wheels?
I take it that you are a stock body on car no flares?
let us know.
Bob B
NARP74
Jul 6 2022, 10:37 AM
No flares, I'll check on the wheel number later today.
Jul 6 2022, 10:42 AM
QUOTE(NARP74 @ Jul 6 2022, 09:37 AM)
8" in the rear with no flares is pushing it (literally).
In addition to needing the perfect offset to make that work (by either getting wheels that have the perfect offset or using spacers to get your wheel in the right spot) you also at a minimum need to roll the fender lip and probably take a baseball bat to work the arch a bit.
NARP74
Jul 6 2022, 10:44 AM
QUOTE(SirAndy @ Jul 6 2022, 10:42 AM)
Noted, I was aware of that possibility when I took on this project.
StarBear
Jul 6 2022, 11:43 AM
QUOTE(NARP74 @ Jul 6 2022, 12:11 PM)
And “Sorry for the inconvenience.”!
NARP74
Jul 6 2022, 11:51 AM
QUOTE(StarBear @ Jul 6 2022, 11:43 AM)
We can meet for dinner at the restaurant at the end of the universe.
StarBear
Jul 6 2022, 02:39 PM
I’ll buy the Gargleblasters!
NARP74
Jul 6 2022, 02:45 PM
QUOTE(StarBear @ Jul 6 2022, 02:39 PM)
StarBear
Jul 6 2022, 03:11 PM
And a quirky story: among other things, I was in charge of the company HQ site intranet when I retired (now 3 years ago). On the last day I added a very small “So long, and thanks for all the fish.”in white font on a white background. So, one couldn’t see it unless it was printed (highly unlikely). I suppose someone has found and removed it by now but I’ve never heard anything. Would be amazing if it were still there, as they don’t update stuff very often.
NARP74
Jul 6 2022, 03:45 PM
QUOTE(StarBear @ Jul 6 2022, 03:11 PM)
That's funny, be hilarious if it was still there.
NARP74
Jul 6 2022, 04:54 PM
So can the rear arms be adjusted laterally? Answered my own question after looking at the setup.
Each one needs to go in a different direction. One wheel spacer on one side? Not sure about the other...
Guess I am looking at arch work or smaller tires for the back.
infraredcalvin
Jul 6 2022, 05:43 PM
QUOTE(SirAndy @ Jul 6 2022, 09:42 AM)
Never heard of anyone getting 215s without some sort of fender massaging…. My guess is that you have 951 stamped Fuchs, as most of the extra width is added to the inboard side of the wheel.
Lateral adjustment this going to be handled by spacers or wheel offset (there might be a little bit of play, but prob not enough to make a difference). Increasing camber helps clear a bit as well. Lateral adjustment at the front of the swing arm affects toe.
NARP74
Jul 6 2022, 08:52 PM
951362.117 AS10.62
sixnotfour
Jul 6 2022, 09:04 PM
951 8's ,,I had 245 /45s on a narrow car fit with a 1x4 ,,rolled fenders ,, I even went back to stock with a small amount of work.. I Gave the 914 back to my Mom..4to6to4cyl.
Before and after.. rub mark is from 15x7s and track tires..Mike Wills Bought em and had to do some more extreme work..
NARP74
Jul 14 2022, 11:56 AM
So what are my options?
Metal work, inner fender and outers, rolling etc.? Not in the cards right now.
Would a 205 55 16 tire in back on the 8" buy me enough room?
Run 7s in front and back, not staggered and same tire sizes front and rear?
Can I run one wheel spacer for the side touching the inner fender? Seems weird.
It came this way so I am trying to work with what I have.
Chris914n6
Jul 15 2022, 12:33 PM
QUOTE(NARP74 @ Jul 14 2022, 10:56 AM)
Not really. 914s are notorious for the rear not being the same side to side. I had to roll my pass side 1/2" to get the same inner space. If a few mm gets it to fit then just do it. The other side you will probably have to roll or camber. Supposedly if you heat the paint it won't crack as easily if at all.
Dave_Darling
Jul 15 2022, 07:12 PM
If you sell the 8s, you should have enough $$ to buy 7s and some 205-width tires to go on them.
Note that those might still rub, but it's much less likely.
8s under stock fenders is almost always a no-go.
--DD
ndfrigi
Jul 15 2022, 07:16 PM
NARP74
Jul 15 2022, 08:42 PM
Thanks for the replies. I'll mount the fronts in the back and carefully check for fitment before I go that route. This was an unfinished project car, I don't think the PO ever got this far with it and never drove it. Just a big list of wishes and dreams.
I could always do this.
Click to view attachment Click to view attachmentClick to view attachment
NARP74
Jul 15 2022, 08:53 PM
Not sure why it rotated my pic. Click on it and it should be good.
NARP74
Jul 16 2022, 02:19 PM
The lips on my rear fenders have already been rolled or whatever it is called.
I mounted the front Fuchs 5 lug 7 J 16 w/ 205 55 16 (951362.115 AS10.62) on the rear, both sides, seems like plenty of room inside and out. I did not drive it since the 8s on the front rub near lock and it might be a little dangerous. Seems like the 7s and 8s have different offsets or something. The room is in different places in the wheel well with the 7s on the rear.
The 8s on a 215 laid flat with a straight edge on it sidewall to sidewall are 9 3/8 inches.
The 7s on a 205 laid flat with a straight edge on it sidewall to sidewall are 8 5/8 inches.
I could buy 2 more 205s since that is what I will probably run and mount them on the 8s just to see. I would then have the tires already and buy 2 more 7s and mount them up.
Anyone have a line on 2 more 5 lug 951 7 inch Fuchs?
NARP74
Aug 8 2022, 09:18 AM
I have read that the 951 wheels were used for added brake clearance. Are they the same specs as the 911 version of the same wheel in the 7 inch size? Why the big fuss over the 951 wheels? These were on the car when I bought it, just trying to figure out the POs motivation and plan for this project.
infraredcalvin
Aug 8 2022, 04:15 PM
No, the 951 8” Fuchs is not the same specs as the 911 7” Fuchs, they have similar offsets 23.3mm vs 23mm, but that’s not the whole story. The 951 8” Fuchs take most of the extra inch width (from 7” to 8”) on the inside of the rim whereas the 911 8” Fuchs take the entire extra inch to the outside of the wheel.
The distance from the face of hub to the inside face of the stock rear fender (on 911s and 914s) is the factor when fitting Fuchs, a 7” typically fits and the 911 8” pushes the tire too far out. So the 951 Fuchs is used, which puts most of the extra tire towards the inside.
targa72e
Aug 8 2022, 10:12 PM
951 are rare as they were a one year option on 86 944 turbos. 951 fuchs are different in many ways. 8" are desirable for 911 folks to run on front of narrow body cars (911 8" are offset to far to the outside to fit) with 9" on rear.
The 7" are different as well. More details on differences in link below.
https://rennlist.com/forums/924-931-944-951...ifferences.htmljohn
NARP74
Aug 9 2022, 03:48 PM
QUOTE(targa72e @ Aug 8 2022, 10:12 PM)
Thanks John, I will read that carefully.
