I have a 72 1.7 mostly all original and the car has had minimal work ever done on it. I’m removing all of the suspension components in preparation to tip the car on its side to replace the floors. I already did the longs and hell hole. I fixed all the other rusty spots with new metal.
I dropped the swing arms and I’m trying to get the bolts out that hold the shocks in. The nuts came off but the bolts will not budge. I’ve soaked ‘em for days with PB Blaster.. submerged the bolt area in evoporust… used a torch and a hydraulic spreader. I’ve beat on them and basically tried everything. Neither side will move. I can’t turn the bolt using a wrench on the shock end. It’s really seized.
So I’m thinking I have to cut the bolt right between the shock and the swing arm.
I’m I missing something? Any ideas? My torch is a map/O2 type and I can get the bolt red hot… at least the part sticking out on the swing arm end.
All the videos and posts that I’ve read show this bolt just sliding out.
