Perplexed... They worked this past fall. Up and down.
The car has sat until now (lack of time) and I decided to replace the rusted headlight assemblies with NOS units. With battery disconnected, relay removed for safety. Started on the passenger side. Removed the old assembly, by unscrewing the three screw inboard pivot, replaced metal pushrods with new plastic pushrods etc. Reassembled and wanted to test passenger popup. Connected battery, relays, pulled light switch and... nothing happened. Popup stayed down both sides. Turned off light switch. Turned manual lift knobs headlight went up then immediately down. Same on both sides. Light switch on, turned manual knob until fully up (stayed up). Turned off light switch both went down but do not go up...
Everything I have done is mechanical nothing with the electrical. I don't know if there is something related but I pulled off the bumper and removed the fog lights to fix rust. The fogs are still removed, wires free and not touching anything. Is there something common with the fogs preventing them from going up?
