cause
Jul 11 2022, 04:13 PM
Will soon be pulling my '75 2.0 motor and doing a full rebuild—which kit you guys recommend? Not planning on doing anything on a track, just reliable and peppier. Was looking at something like this:
https://aapistons.com/products/vw-type-4-pe...ne-rebuild-kitsWhich CC is reasonable? which cam are people running? I already have 40 IDF Webbers and Bursch exhaust
R Dub
Jul 11 2022, 07:44 PM
I went with 96mm Keith Black pistons and cylinder kit from FAT performance when I built mine a few years back to make it 2056. This way I could use the same crank, rods and case as those were all good. I did a Web cam#86 which matches the dual webers I'm running. Car runs pretty darn good. I can't say how much peppier it is over stock cause I never drove it stock but it is very fun to drive.
lesorubcheek
Jul 11 2022, 08:18 PM
Options have changed since working on mine back in the early 80s, but I'll throw out what it has just as a data point for you. Pistons were the euro factory flat tops that I think gives about 8:1 for the compression. Same displacement. Camshaft was a WebCam, pretty sure like the 00-152. I didn't change it out from the PO and he said it had a "3/4" cam in it, so assume it was something like the 00-152 since it seems popular for carbs. Dual IDFs of course. Also a 009 distributor. I've heard lots of bad press about them, but honestly it never bothered me, it was always fun to drive. Maybe if I'd tried a different distributor I'd have noticed the difference.
It had a really strong mid-range. It'd pull from 45mph in 5th without gearing down so very tractable in traffic as a daily driver. Not that I lugged it down often, but just saying it pulled strong especially in the 2000-4000 rpm range. It always cranked easily hot or cold. Only serious failure was after about 5 years a valve guide worked loose and ruined one of the heads and a piston/cylinder. I rebuilt it putting the same type euro pistons and 2 new heads. Might have 5000 miles on it since then.
Dan
cgnj
Jul 12 2022, 05:54 AM
This is the way to go. More displacement reduced rotating mass.
barefoot
Jul 12 2022, 07:39 AM
I also converted my 2.0 to a 2056 using flat top pistons & no cylinder head spacers/gaskets & a WEB 494 cam with dual Dell 40's. Very pleased with the performance, I usually don't bother with 1st gear except for an uphill start, good low end and no flat spots. I had the cases align bored and cylinder spigots decked so run about 8.4 CR. I never see oil temps over middle of the gauge and cylinder head temps measured at #3 plug stay below 300 although I don't drive hard. Don't use aux oil cooler, just stock. I was very careful to clean out casting flash in the cylinder head cooling passages as most of them were very compromised with excess flash.
