slivel
Jul 12 2022, 12:09 PM
For us black oxide novices who want to dip our toes into this for our 914's, in your original post you said that the surface has to be very clean. What did you do? Your parts look great.
Did you do media blasting, just hand work with emery cloth, wire wheel, something else. TIA.
914Sixer
Jul 12 2022, 01:46 PM
Used wire wheel on most, then did a vinegar soaking. Checked everything from there. Some required a second round of cleaning.
nathanxnathan
Jul 12 2022, 06:25 PM
I'd like to see Caswell's zinc black chromate kit in action.
Literati914
Jul 12 2022, 08:19 PM
would the black oxide be a no-no on bearing surfaces such as you have at the axle assemblies?
Costa05
Jul 12 2022, 09:10 PM
I did the same on almost all of my hardware. Really wanted black so gave it go. Turned out great. So far at least.
friethmiller
Jul 13 2022, 10:11 AM
If anyone is curious, I photo-documented my efforts in Zinc-Nickel and Zinc plating for my 914 on my smugmug site. Just a dozen or so images but each one has a few details of the action. I went "high-class" with my paper plates and scotch tape. Most of the bolts and washers were purchased from Belmetric but I did re-plate the door bolts. Another thing to keep in mind your drying rack. I recommend you take time to have a better setup than I did. My fan blew some of the small parts into each other, which messed up the 'still delicate' chromate.
https://fredriethmiller.smugmug.com/1974-Po...Apr-Jun-2020/59
ValcoOscar
Jul 13 2022, 02:44 PM
QUOTE(friethmiller @ Jul 13 2022, 09:11 AM)
https://fredriethmiller.smugmug.com/1974-Po...Apr-Jun-2020/59_____________________________
Simply E X C E L L E N T
D'man of the day
O
Vysoc
Jul 13 2022, 03:28 PM
Nice work, thank you for sharing!!
Vysoc
