QUOTE(mgphoto @ Jul 14 2022, 01:53 PM)
Idle for a type vi is very much dependent on the load, my idle is set at 1050, with the headlights on.
It can jump slightly higher, without the headlights and the voltage regulator switching off alternator load.
I set the idle at 1050 rpm because I run a lightened flywheel, the idle tends to dip very low on braking, works very well for me.
I experienced the same prior to 123 distributor install. Now when I turn on the headlights, fog lights, fan the rpm (at idle) dips for a second then return to 1000 rpm.
Can anyone explain to me why load is an issue with the stock dizzy but not the 123?
