Hijack, sort of. I apologize. A couple of months ago my horn would occasionally beep as I made a turn. The horn ring on the steering wheel became a little higher on the right and depressed on the left. Then, a few weeks later, the horn stuck on. I removed the horns from behind the driving light grilles. Now the horn ring is loose in the on/off mode but is still in its proper rotational position.
I'm guessing that there have some sort of plastic spacers that hold the ring in the correct spacing. I am hesitant to try and remove the assembly. I read that the horn ring can be removed by holding it separately from the wheel and rotating it counter clockwise. Have any of you seen this problem before? I'm OK with not having my horn but I would rather have it back. One thing that I DON'T want is to have the ring broken off.
Any advice is appreciated. Again, sorry mmichalic for the hijack, at least it's about the steering wheel.
