QUOTE(FlacaProductions @ Jul 18 2022, 02:35 PM)
Picture number one - with the single circle.
Find the slot head screws on that cover where the cables are going over it - remove the cover, drop the speedo and clutch cable below it and then replace the cover.
easy peasy.
sticky fingers will be doing an engine tear down in no time.
@FlacaProductions . looking at stickyfingers engine bay and underside photos, seems as if taco plate sensor was once connected to oil temp gauge but has since been snipped off and the set up is now all on top of the engine in the gadget connected to where the oil pressure idiot light is stock. there appears to be two separate electrical connections to that set up. one for pressure? one for temp?
@stickyfingers . looking at your photos do i see a 1974 1.8? is that what you got?
looks like it from the muffler and some other clues but not sure.
if so have you got time to give us some data for research we have been doing on 1.8s.
(if its not a 1.8 don't worry about it.)
here is what we need.
1) VIN # (sticker in the drivers door opening near door latch).
2) Karmann number. thats the little plate rivetted to the drivers door jamb where the hinges are located.
3) emissions sticker. this is located on the left hand side of the engine bay just above where the engine bay relay/fuse box is.
4) tune up sticker. this is located on top of the engine on the left hand side. its white with some funny little cartoon like drawings on it.
5) evaporative emissions cannister. is it in the front trunk on top of fuel tank or its it in the engine bay on the back firewall of engine bay above engine.
6) there is a paint stamp stencil on the engine. its usually on the left hand side and hidden by the heater fan hose pipe. probably one of 4 numbers. 604, 605. 606 or 607.
sometimes its on the right hand side of engine near where the battery is. its stamped on the black painted engine tin and its white paint.
take some photos if you have time and post them up.
if you don't want to give out your Vin and K number on the open forum you could PM them to me.
