Can the brain trust please advise me on the no-start condition I have on the 1974 914-V8 conversion I picked up here on the World? (Please skip to question one - i.e. the big question- regarding the starter switch, if you’re short on time).
The starter will engage but the engine will not start as it feels like it is getting no power. I did unhook three wires from the GM “F234” regulator as well as one from the alternator and I also cleaned the body ground on the battery cables. Obviously I know nothing about electricity/wiring so it is entirely possible I screwed something else up. What I definitely messed up was the position of the wires when I reconnected them to the regulator. They were in the correct order but offset one pin to the right (2,3,4) from their original location (Original was : F,2,3-there was no wire on the fourth pin).
I figure I probably fried the regulator when I replaced the wires one pin off because it felt hot. I bought a couple of new ones and put one of them on and checked the custom fuses in the center stack from the previous owner and none of those fuses were blown. I did not check the oem fuses yet. The new regulator did not fix the no start issue.
It started and ran fine when I had a water leak at the front of the block and had to redo the cooling system and takeoff the water pump and alternator a few months ago. Prior to the water leak I had completely replaced the fuel system and that worked perfectly (at least for the 46 miles that I drove it at low speeds with only two gears -due to badly worn shift bushings) before the water leak ).
Although I’m having a tech friend try to track it down hopefully early tomorrow morning, I have a few questions that hopefully you can address.
The big question is: if the starter switch were going bad or was cracked and broken, is it possible that the starter would engage but the engine would get no power and therefore not start?
Second question: the “F” pin on the back of the alternator is loose - would that prevent the car from getting power even though the starter engages?
Third question: If I blew a factory fuse when I possibly burned out the regulator, which one would it be in all likelihood (counting from left to right I guess)?
Thank you for your support, as always!
