QUOTE(NARP74 @ Jul 17 2022, 11:21 AM)
My guess is this is not factory. Where should it be on a 3.2?
On a 3.2 the cht sensor screws into the side of the #3 cylinder head.
Look at the sheet metal covering that rear section you should see the wire hanging through it. That is if its in a 911 and factory motronic. If not it could be covered up with the engine sheet metal . Either way look at the #3 head.
