jim_hoyland
Jul 18 2022, 04:47 PM
The bolts are badly rusted and two have rounded heads.
914Sixer
Jul 18 2022, 04:52 PM
ACE, Lowes, Home Depot. Make sure they are 8.8 or better.
NARP74
Jul 18 2022, 04:53 PM
My local Ace hdw has metric. Online is Belmetric and another I can't remember right now.
914e
Belmetric.
NARP74
Jul 18 2022, 04:55 PM
The local Ace has single parts in bins The Lowes and Home Depot went to bags of hardware and not much of a selection. By me anyway, YMMV.
jim_hoyland
Jul 18 2022, 05:02 PM
Thanks ! Ace is the Place….,
jim_hoyland
Jul 18 2022, 05:41 PM
What size bolt for the larger front bolt ?
bbrock
Jul 18 2022, 06:43 PM
My local ACE is limited on metric, especially lengths. I usually can find something that will work, but isn't the exact right part. I usually look up the correct size in the PET and then order the exact match and finish through Belmetric.
nathanxnathan
Jul 18 2022, 07:22 PM
Looks like #2 and #9 here
Click to view attachmentso M12 x 1.5 x 80 — Pretty long, McMaster only goes to 70mm. Pelican has genuine Porsche for like $14 a bolt.
The smaller are 8mm x 8, presumably 1.25 pitch.
jim_hoyland
Jul 18 2022, 08:58 PM
Thanks Nathan
Why is that bolt 80mm
914e
Jul 18 2022, 09:19 PM
I think it is 9 and 6 that hold the cover on. The M12 x 80mm holds the support beam on and is a 19 mm head size.
nathanxnathan
Jul 18 2022, 10:01 PM
QUOTE(914e @ Jul 18 2022, 08:19 PM)
Ah yeah that makes sense — I just checked my project and the bolts into the frame/car are 10 mm and the ones into the auxiliary support/crossmember are 8 mm.
windforfun
Jul 19 2022, 06:15 PM
QUOTE(nathanxnathan @ Jul 18 2022, 09:01 PM)
Go with SS if you can & don't forget the lock washers. Flat washers may be necessary too depending on the cover holes.
windforfun
Jul 19 2022, 06:16 PM
QUOTE(jim_hoyland @ Jul 18 2022, 03:47 PM)
Looking good!!! My car was undercoated like yours.
jim_hoyland
Jul 19 2022, 07:02 PM
QUOTE(windforfun @ Jul 19 2022, 05:15 PM)
Done, Ace had everything. Problem now is to get the old bolts out. It’s awkward getting at them from the floor;the head of one M8 is wearing away plus a tough angle.
windforfun
Jul 19 2022, 07:54 PM
QUOTE(jim_hoyland @ Jul 19 2022, 06:02 PM)
Vice grips & maybe PB Blaster too.
