Full Version: Center console heat indicator
914werke
Odd ball question, in the center console (as well as non equipped cars) there is a small square illuminated indicator for the heater lever, this is on anytime your lights are on.
When installed on the center console it originally had a odd H shaped seal beneath it.
Does some one have one or an image they can share?
Additionally has anyone ever bothered to alter that circuit so that indicator is illuminated ONLY when the lever is pulled?
StarBear
Here’s mine. Just the plastic plate and bulb. Is the seal below the plate, or above (then mine is missing or not on a 74).
.Click to view attachment
914werke
Supposed to be below, I only found one in soooo many years.
There is no PET diagram of the console Ive ever seen
rjames
Here ya go, Rich:
Correct orientation:
friethmiller
Ok, Dumb question. What does this button thingy even do?
rjames
Misunderstood friethmiller's question. Post deleted.
friethmiller
QUOTE(rjames @ Jul 20 2022, 11:54 AM) *
QUOTE(friethmiller @ Jul 20 2022, 09:38 AM) *
Not much. I think think it just allows the plastic base that sits on top of it to seal against the vinyl better so that there are no gaps.
LOL! No, sorry... my question is EVEN dumber blink.gif What does that button do? I haven't hooked mine up yet.
BillJ
Nothing. Its just a light illuminating on and off for the heater pull.
friethmiller
QUOTE(BillJ @ Jul 20 2022, 01:24 PM) *
Ah! okay. Makes sense. Thanks.
914werke
QUOTE(rjames @ Jul 20 2022, 09:30 AM) *
Here ya go, Rich:
Awesome Thank you!
wonkipop
QUOTE(friethmiller @ Jul 20 2022, 01:46 PM) *
mine is even dumber than that.
just illuminates when you turn the lights on.
-----which is @914werke 's question.
can you wire it up to come on when you pull the handle up.
i guess so.
914werke
I know you can, I just hoped someone ELSE had already done the work & I could just benefit biggrin.gif
rjames
QUOTE(914werke @ Jul 21 2022, 08:18 AM) *
914werke
Green wire to lever is hot with key on, when pulled is grounded to power the fan circuit.
Black w/blue to lamp is illumination & is already grounded only energized when light switch is pulled.
So in theory you could disconnect the the existing Black w/blue & the ground from the lamp, branch a
wire from the heater lever hot to the lamp & walla !?
Will that little lamp deal with the voltage/amperes?
FlacaProductions
Even if you do, will it be bright enough to see in the daylight?
I'd go with the mod where you put a lamp in one of the empty sockets behind the fan speed control panel and connect the ground to the lever - when it grounds to turn on the fan, it also turns on the lamp. fill it with an LED and it should read even in daylight.
914werke
I like the idea of going LED for brightness, what is the stock incandescent bulb for the OE indicator?
wonkipop
QUOTE(914werke @ Jul 21 2022, 02:17 PM) *
914werke
Thanks!
Ive looked at that page IDK how many times & never noticed the indicator was on it.
Notice there is no part for that little seal?
wonkipop
QUOTE(914werke @ Jul 22 2022, 07:39 AM) *
Thanks!
you are not the only one.
only reason i know is i had to track the bulb down 2.5 years ago.
searched through that parts catalogue 20 times before i finally saw it.
so i knew where to go for you.
yep no gasket.
its a mystery part.
EDIT
its not even on the console parts page.
i just went and had a look there.
