Hi all,
I have recently purchased a '74 1.8 with the original L-Jetronic fuel injection. It runs fine but there are two strange things going on with the engine wiring. On the front passenger side of the engine, near the battery tray, there are three wires that have been disconnected. I don't see anything that I can connect it to. Does anyone have a clue where these should go?
The other question I have is regarding some wiring on the relay board. There is a yellow wire coming from the wire harness that connects to the empty connector slot on the rear drivers side part of the relay board. Is that supposed to go there? And secondly, a previous owner attached a switch that connects the upper right pin to the lower left pin (where the yellow wire is placed) Does anyone have an idea what this would be used for?
Thanks in advance for the help!
