QUOTE(piscean914 @ Jul 22 2022, 04:56 PM)
- hey guys - i'm at the 2022 wcr - my front latch slipped and i think i adjusted it correctly, but it really bugs me so far from home
- is there an emergency/alternative pull to release the front trunk latch if the cable release does not work?
- i can't see any access points ('76 914) on the driver side to run some sort of cable attached to the front latch
any answers (with images) would be great
thanks!
opposite side of the world.
had the same problem today (for first time in 34 years).
went to fill up with gas. no go on the front trunk.
mine is a 74.
had the front bumper off in a hour.
(work slowed by carefully soaking the bolts in WD 40 and working them a little bit).
the bumper had probably never been off.
bumper on a 74 is a 10 minute job with nice condition bolts.
fortunately the bolts freed (job could turn into a bit more of nightmare with sheared bolts. would not stop you getting bumper off but would have dragged out getting it back on.
dunno about a 76.
i tried the old push down trick with my mate across the road lending a hand.
no go.
turned out my cable was stretched after all this time.
i have been feeling it get progressively worse for the 2 years i have been back on the road. just been ignoring it, until i couldn't
adjusted it and its working good again.
lubed the hell out of it while i was in there.
i don't think there is a workaround unless you rigged up a second cable somehow.
like a custom job. hidden behind the valence maybe with a little handle. be a bit of trouble to do. not sure how you would attach that cable.
