Good morning everyone,
I hope you and your families are all doing well in these difficult times.
It is many years since I adjusted the tappets on a Type 4 engine as in my 914 so I want to double check some odd results I am getting.
I checked on Youtube and it is suggested that one way to find TDC etc is to check TDC on No 1 cylinder and the timing mark shows in the timing hole (when both tappets are slightly loose, to confirm) then turn the engine backwards 180º then check cylinder No 2, repeat process for No 3 then again for No 4 cylinder.
The other suggestion in the Brooklands Books Owners Workshop Manual is to remove the distributor cap, line up the rotor arm with the notch on the side of the distributor, with the timing mark showing in the timing hole, then you are ready to adjust cylinder No 1. For No 2 cylinder turn the engine the normal way (clockwise) 90º then you can check Cylinder No 2, repeat again for No 3 then No 4.
I have tried both ways, No 1 OK, then No 2 does not have both valves fully closed. Then when I try No 3 that's OK then No 4 again the two valves are not fully closed.
I have the engine out as I am in the process of checking my "new car" over before I start doing some serious milage, so access to the engine is easy.
Anyone else ever come across this situation. As mentioned, I am no novice but this has me beat!
Any suggestions would be gratefully received.
