QUOTE(mepstein @ Jul 24 2022, 09:45 PM)
They sell a special tape that you can wrap around the spindle and it resists the oven heat. You can probably just tell the powder coat people to mask it off and they should have the proper tape.
My powder coat guy provides his own making material and/or silicone caps.
However, On struts, be sure to tell him not to powder coat the tie rod taper on the steering arm. In my case, I took the ball stud out of old worn tie rods and used that to fill the taper so that there was no possibility of getting powder coat into that critical taper.
Likewise, you'll want the strut gland nut threads protected, they are fine thread and are not easy to clean out. Again, used old gland nuts and just installed them loosely into the top of the strut to keep powder coat out of the threads.
@sixaddict
