A while ago I posted a picture of the drivers side control arm. It was elliptical indicating a twist somewhere. Torsion bar was straight and body measurements against the shop manual indicated the car was not twisted. I think I've found what cause this problem. This is what I posted:
A few weeks ago I showed my kid how to high pressure the car. The drivers side wheel well had undercoating.
BTW - She eventually started to look at what she was doing.
This is what I found:
Other than the heat I see applied in a few areas, I don't see any body damage. How exactly do you cause this crease? I'll re-measure the front diagonals to verify it's straight. What else should I be looking for or checking since this crease is near the back of the control arm mount?
Thanks,
DaveB
