rosenfe
Jul 27 2022, 01:16 PM
On my 74. Took a bit of persuasion, but bolts and case tightened up. Trans is in nuetral , can I assume spline mated correctly?
brant
Jul 27 2022, 01:17 PM
if the gap closed.. and the bolts tightened... it has to be in the splines
NARP74
Jul 27 2022, 01:28 PM
Don't use the bolts to close the gap if it does not go by itself. Great way to break a tab off. Could you close the gap just by pressing it together?
rosenfe
Jul 27 2022, 01:44 PM
What tab are you describing
rosenfe
Jul 27 2022, 01:46 PM
No I could not close by pressing. Doe trans need to be in gear to be able to rotate?
rosenfe
Jul 27 2022, 01:52 PM
What I meant was does trans need to be in gear when mating, to allow for spline rotation and fit
914e
Jul 27 2022, 01:59 PM
QUOTE(rosenfe @ Jul 27 2022, 12:52 PM)
If you trying to get the input shaft to rotate from the output shafts yes it has to be in gear, and you have to turn both output shafts otherwise you are just turning the other output in the opposite direction though the differential.
Montreal914
Jul 27 2022, 09:29 PM
Clutch disc not concentric in the flywheel?
targa72e
Jul 27 2022, 10:22 PM
Concur If you cant push it together by hand realign the disk with tool and try again. If you forced it by bolting things down you might be lucky and not have damaged anything and get try again. ... otherwise might have a pile of
john
rosenfe
Jul 28 2022, 07:17 AM
Should trans be in gear to all better alignment while turning flanges?
bbrock
Jul 28 2022, 07:28 AM
QUOTE(rosenfe @ Jul 28 2022, 07:17 AM)
Doesn't matter as far as I've seen.
friethmiller
Jul 28 2022, 08:27 AM
I recommend pulling it back apart and trying again. Check the clutch plate alignment (and other recommendations listed here). It should go together without using the bolts.
rosenfe
Jul 28 2022, 01:01 PM
I’m going to take your advice and pull it apart. Start over
rosenfe
Jul 28 2022, 07:02 PM
Separated trans from engine, no damage. It really wasn’t seated all the way. Reinstalled closely paying attention to lower bolts and it slid right in. So glad that I reinstss as led, now I don’t have to worry about the trans. Plus it was just rebuilt
rosenfe
Thanks for all the good advice
