My understanding is Type 4 valve clearance is 0.006" for all stock engines except stock 2.0 exhaust valves. This is for the greater expansion of the sodium filled valves the factory installed.
I've seen the same recommendation for rebuilt engines with stainless steel valves for exhaust and intake. If stainless steel valves are used on the exhaust, shouldn't lash be set to 0.006"? If the 0.008" is recommended to ensure valve closure, shouldn't the intake be set to 0.008" too?
I'm not sure this matters, but my setup has custom cut Al pushrods with 1.7 rockers/swivel foot tappets.
