If all fuses are passing current (you can verify with an ohm meter) then look at the red wires that connect to the positive terminal of the battery
QUOTE(mmascari @ Aug 8 2022, 08:18 AM)
I have an electrical issue that I could use some assistance with. My car is a 73. Any thing that runs off the ignition switch in the On position has suddenly stopped working. None of the gauges work and my fuel pump which I relocated to the front using terminal 7 on the fuse panel also does not turn on. Any ideas? The problem started when I pulled the fuse panel down to check the wiring for my fuel pump.
