QUOTE(930cabman @ Aug 9 2022, 08:20 PM)
I'm holding to my guns
To consider any part of a modern engine to receive a static balance is just wrong.
Just to be clear about what is being proposed, it isn't to do a static balance. Nothing is to be adjusted.
What is proposed is to find out where the pulley and impeller achieve static balance as an assembly as it left the factory. It can only go together one of four ways.
One of those four (180 degrees out) will be clearly wrong since the pulley weights will be 180 degrees out from where they ought to have been when it was originally balanced. This will not static balance since the balance weights on the pulley are now adding to what ever imbalance was in the impeller.
One of the four will be right (0 degrees) -- it will static balance as it left the factory. Since the weights have not moved from factory position, it will be dynamically balanced to the same extent as it left the factory assuming it had zero radial run-out when it left the factory.
The other two (90 degrees and 270 degrees out) are up for grabs. If the weights are very small, it might be hard to tell in these positions if we've returned the assembly back to the same static balance the assembly had when it left the factory. If the weights are large, static balance won't be achieved in either of these positions.
Overall - I'm with you. It would be better to send it out and have the whole fan, crank, and flywheel/pressure plate dynamically balanced but that doesn't seem to be on the table.
This was more of the thought excercise to figure out how to return the pulley/impeller assembly to the same condition that it left the factory in. Of course, we are ASSUMING all fasteners weigh the same and can have their positions intermixed without ill effect. The chance of returning all fasteners to
exactly the same position as it left the factory are about as good as winning the Lotto.
