jim_hoyland
Aug 8 2022, 09:19 PM
Two questions;
1. After watching the PMB rear caliper rebuild, I’m curious what’s involved in the front rebuild
2. Do the front 914 and front 911M calipers use the same rebuild parts ?
bbrock
Aug 8 2022, 09:28 PM
PMB has you covered on how-to for rebuilding the fronts too:
https://www.pmbperformance.com/brakehowto.htmlFronts are very easy compared to the rears. Not sure if the parts for 914 and 911M are the same, but PMB has rebuild kits.
mgphoto
Aug 9 2022, 10:56 AM
911 and 914/6 have a larger piston than the 914/4 none of the parts are the same.
jim_hoyland
Aug 9 2022, 02:56 PM
Lastly: are the 911M rear calipers different compared to 911M front calipers
If Yes, what physical characteristics tell which is which ?
davep
Aug 9 2022, 04:38 PM
48mm 911 & 914/6 front
42mm 914 front
38mm 911 & 914/6 rear
33mm 914 rear
jim_hoyland
Aug 9 2022, 05:49 PM
Thanks
