QUOTE(mgphoto @ Aug 11 2022, 09:02 AM)
Factory manual is lacking in detail, type o’s and misinformation. If you study the factory manual also read the Sportomatic section as it has greater detail and fewer mistakes. The numbers are completely different but the procedures are the same.
The Dr. Evil DVD is the best source for rebuilding buy a copy and watch it over and over, better yet get a cheap tail shift transmission and practice along with the DVD.
I used to think there was some bad “mojo” inside the 901 box but once you understand what it does, it becomes another mechanical device.
I have 2 cores, 1 side shift, the other tail shift, so I guess I'll start by pulling the tail shift apart, then pull the transaxle out of my race car (close ratio side shift with 904 main shaft with LSD) and get on with fixing, maybe upgrading depending on what i find....
