I had my car 4 wheel aligned yesterday and overall went well. I've replaced all the bushings, shocks, struts, springs, bearings, etc so it was all totally out of wack....
Good news, everything came into spec in front. All good. Car drives great now. In the rear I needed a bit of camber to clear the tops of my tires, so I am sitting here:
Rear Left:
Camber: -1 deg 24'
Toe: -0 deg 18'
Rear Right:
Camber: -1 deg 12'
Toe: -0 deg 02'
Camber: Factory says max difference from left to right is +/- 20'. I've got 12' difference side to side so I think I am okay there, even though the extra camber may cause some tire wear that I can live with.
Toe: Factory says toe should be 0deg +15' per side. The alignment shop set limits to 0deg +/- 15'.
A lot of numbers and I can make a bunch of guesses, but I would like to know for my road car which gets some spirited hill country driving, should I work on getting more positive rear
Sorry if this is beaten to death or overcomplicated. Writing it down here helped me get it straight in my head. If it helps, below are my suspension settings and condition. Car was corner balanced prior to going for alignment, and is slightly lowered. Clearance on the RH side (passengers) rear tire is tight but it does clear with the current settings.
Front:
Stock Torsion Bars
15mm stock front anti sway bar with new bushings
Turbo Tie Rods
New Ball Joints
New 914 Rubber bushings
New front Koni Red externally adjustable strut inserts.
New Wheel Bearings
16x6 5 lug Fuchs
Bridgestone Potenza RE980 A/S Plus, 205 /55 R16
Rear:
New 100lb Eibach coils
Ground Control adjustable spring perches
Koni Red adjustable shock absorbers
New rear wheel bearings
16x6 5 lug Fuchs
Thanks Guys!
