QUOTE(914werke @ Aug 15 2022, 11:29 AM)
Ive tried repairing that issue in the past & was never happy with the outcome.
When the heater wire breaks off like that, it is very difficult to repair.
I've tried cutting away the steel sleeve with a lathe to expose enough of a stub to solder on a new lead. FAIL on 1 of the 2 that I've done.
I've taken one apart completely to try to fix from the inside. FAIL. If I recall properly, the lead is rivited to the ceramic bowl that contains the heater wire. Didn't see an easy was to make a reliable electrical connection that would survive (i.e. solder won't work) the heat produced by the heater.
So my total success is 1 for 3 and I don't even trust the 1 that "worked" that much it will be far to easy for that power lead to short to ground in the future -- it will be a emergency backup.
