QUOTE(DennisV @ Aug 17 2022, 02:52 PM)
Is there not a condenser used on 914-6 with a Marelli distributor?
I don't see what looks like a condenser in the parts catalog. Nor can I find mention of the word "condenser".
Click to view attachmentYet
Sierra Madre lists 90160293100, as do other vendors.
Marelli Distributor Condenser, 911T (68-71)/914-6(70-72)
I don't find that part number searching the catalog either.
The CD Ignition used on the 914-6 only sends a very low voltage through the points. All of the high voltage is handled at the coil and in the CD box. The only reason you have to change the points in a 914-6 is rubbing block on the points wear out, causing a dwell change.
The 1965 911 had a kettering ignition (points and condenser). The engine fouled plugs on a regular basis. So the CD ignition was developed to provide a hotter spark to prevent fouling of the plugs. That's why there is a condenser mount on the Marelli distributor. But the condenser was never installed.
Hope that explains it.
Clay
