steuspeed
Aug 19 2022, 06:14 PM
How do you get the damn thing out?
hndyhrr
Aug 19 2022, 06:20 PM
Two bolts on the side (think they are 10mm) take em out. unplug electric. unhook bowden cables. wiggle it out up and forward. It's easier to take out than go back in, ask me how i know. lol
914sgofast2
Aug 19 2022, 06:36 PM
Disconnect cardboard air tubes. As noted, remove two 10mm bolts on right and left sides under the cowl. Push up on air box and pull forward from bottom. Once it’s far enough out for access, disconnect cable that operates flapper valves for air tubes. Then on bottom, disconnect the square black plastic wiring plug that powers the electric fan motor. It also helps to remove the black plastic drain pipes from the bottom sides of the fan housing.
aharder
Aug 19 2022, 06:37 PM
I think Ian Kerr has a YouTube video on it.
bkrantz
Aug 19 2022, 07:57 PM
Extra hands to pull up hard (but carefully) on the cowl while you pull the airbox forward makes it easier. And before you do that, loosen the cowl braces on either side.
jim_hoyland
Aug 19 2022, 09:07 PM
QUOTE(aharder @ Aug 19 2022, 05:37 PM)
Yes
After doing this, the video is a great help.
steuspeed
Aug 20 2022, 12:48 AM
I saw one where he was putting it back in, but skipped the cable connection part which is what I need.
steuspeed
Aug 20 2022, 12:51 AM
QUOTE(914sgofast2 @ Aug 19 2022, 05:36 PM)
I got it about half way out. Unsure on how to get the cables off.
barefoot
Aug 20 2022, 08:52 AM
It helps to disconnect these 2 braces to give the cowl more freedom to move slightly.
one of the fixing bolts is seen as well.
steuspeed
Sep 19 2022, 11:43 PM
I got the air box out. The trick is to push the fan lever on the dash all the way one way until the cable linkage peaks out on the passenger side of the box. You can just get to the 7mm screw that secures the cable wire. Once that is loose, you can manouver the box a little more so you can get to the cabe housing clamp screw. Dissconnect the 4 pin wire harness plug. Now the box is free and will come out.
