prrt1
Aug 21 2022, 03:09 PM
Need help please! I have a certain car (someday it will be a Porsche) with D-jet, rebuilt manifold air pressure sensor, new injectors, new fuel pressure regulator, and a new PC board in the Throttle Position Switch. While cruising, I get a hesitation (pretty severe) that feels like some is flipping a switch off/on. Wondering if anyone can give me an idea what might be wrong? I hope my terminology is OK..and I searched but no results...
Thanks for any help.
mgphoto
Aug 21 2022, 03:20 PM
Clean the trigger points in the base of the distributor.
StarBear
Aug 21 2022, 03:27 PM
Or maybe water/moisture in gas. Happens (to me) this time of year with partial tank of gas and high humidity then condensation overnight. Fill up tank with a quality gas.
brant
Aug 21 2022, 03:41 PM
Maybe double check the TPS position with an ohm
BeatNavy
Aug 21 2022, 03:44 PM
This one has a lot of potential causes. It could be fuel delivery related or ignition related.
On the fuel side:
Dirty fuel tank "sock" filter
Clogged fuel filter
Problem with fuel pump
Loose injector grounds (check the 3 prongs at back of engine case)
Loose injector connectors
Clogged injectors (not likely in your case with new injectors)
Bad or misadjusted trigger points
Bad, dirty, improperly adjusted TPS
Ignition side:
Loose spark plug wires
Something wrong with or in distributor -- check ground strap, check condition of dizzy cap and rotor, make sure points are in good shape and adjusted properly
You can eliminate the TPS as a variable by unplugging the connector at the TPS. Car won't accelerate as well, but it will run ok and you can see if the problem persists.
Try the easy things first: check injector connections, injector grounds, spark plug wires, and condition of dizzy components.
There are a LOT of threads on this. Try searching again "bucking while cruising"
http://cse.google.com/cse?cx=0024083458981...772:ajvfxschcgc
prrt1
Aug 21 2022, 04:31 PM
Excellent suggestions everyone...thanks very much!
emerygt350
Aug 21 2022, 05:06 PM
Is it only cruise and only when you are just barely keeping the throttle open?
And is it the stock distributor?
930cabman
Aug 21 2022, 05:09 PM
QUOTE(BeatNavy @ Aug 21 2022, 03:44 PM)
On the fuel side:
Clogged fuel filter
Ignition side:
http://cse.google.com/cse?cx=0024083458981...772:ajvfxschcgc could be as simple as a clogged fuel filter. Keep the faith and let us know of your results
prrt1
Aug 22 2022, 03:55 PM
Original dizzy, ca. 1975. I have suspected the trigger points, took them out, cleaned, and seem to be OK per Dr. D-jet specs, but I think the rub blocks are at their limit. New fuel filter, checked the pump inlet and it seems to be OK. Crane ignition (no points.)
The bucking happens at about 2000 rpm, 50 mph or so, but it has happened on acceleration also.
I'm getting much good input from everyone, will try a few things. I will reveal the car is a 1974 BMW 3.0CS into which I installed D-jet from a '75 coupe. Joined this group because, well, Porsche guys are as fanatical as BMW guys and hope there is some knowledge I can pick up...
Thanks.
DRPHIL914
Aug 22 2022, 04:31 PM
QUOTE(brant @ Aug 21 2022, 05:41 PM)
if you use an eraser to clean the TPS board, it may clear this up,, i had exactly the same issue that no matter what i did it didnt clear up until I cleaned that off. If the tracers have marked the board too deep and you cant just clean them off, Dave Sprinkle makes new boards.
Phil
emerygt350
Aug 22 2022, 04:55 PM
He has a new board in the tps. I am starting to think you really need to adjust it by hand in some cases. I was having to do this recently as well. By that I mean setting it 'correctly' on the bench doesn't always cut it.
prrt1
Aug 3 2023, 02:27 PM
Welp, a year later and I still have hesitation, sometimes severe (as though the engine momentarily shuts off, it bucks, but doesn’t stall), I tested everything as suggested herein. I think I have narrowed the problem down to the TPS: My car runs OK with the TPS disconnected, but as soon as I plug it in, I get burps and eventually more severe hesitation. I have fiddled with the TPS (it has a PC board only a couple of years old) to no end. I’m thinking it might be a bad wire to the ECU, but before I rewire it I was wondering… if everything is OK without the TPS, what do I need it for? Thanks for all your help.
brant
Aug 3 2023, 02:42 PM
car normally runs without TPS
but does not run well
TPS is important throttle information for the "computer"
adding additional fuel...
you need it.
did you try to set it correctly with an OHM meter?
did you try to clean the board inside of the TPS housing
then next replace the board if you have done the above
and reset it correctly to baseline with an Ohm meter
windforfun
Aug 3 2023, 02:47 PM
Did you align the new TPS board exactly like the old one? Are the two boards geometrically identical?
emerygt350
Aug 3 2023, 08:54 PM
Are you sure this isn't a lean miss?
TX914
Aug 4 2023, 05:43 AM
May want to check CHT sensor and CHT lead wire for wear/corrosion. Assuming lead is good, a quick test for CHT is with engine warm, remove lead and ground it.
Tom_in_NH
Aug 4 2023, 12:49 PM
Classic symptoms of a D-Jet TPS issue. Very detailed investigation here:
https://sw-em.com/bosch_d-jetronic_TPS_investigation.htm
windforfun
Aug 4 2023, 01:09 PM
prrt1
Oct 12 2023, 03:25 PM
I have found a “solution” to my cruising hesitation and severe bucking problem in my D-jet equipped BMW (I’m writing to 914 World because you guys set me in the right direction. D-jet BMWs are few and far between in our world.)
Anyway, the posts in 914 World gave excellent information (especially Tom in NH) about this problem but no one seems to have identified how to fix it.
My solution was to cut wire #9 between the TPS and the ECU. Wire #9 connects one of the sawtooth traces in the TPS. I found this by chance, but the severe bucking and cruising hesitation is gone, except for a very minor stumble when shifting from 1st to 2nd. Also the hard starting-when-warm problem has disappeared. I don’t know why this fixed the problems, but I running with it for now.
I want to thank 914 World for all the help they have provided in my 2-year struggle to fix this problem.
rjames
Oct 12 2023, 03:37 PM
QUOTE(prrt1 @ Aug 22 2022, 02:55 PM)
Thanks.
Cutting wires isn't a good fix. I'll have to go find a wiring diagram to see what that wire does. But I just re-read one of your original posts where you said the bucking happens at 2000 RPMs at 50 MPH. Is that during acceleration or while you're 'crusing'? Because that RPM is way to low to be crusing at, and I would expect the car to buck a bit and generally be very unhappy if you're crusing at 2k RPMs. You should be at 3K RPMs or higher.
brant
Oct 12 2023, 03:44 PM
But he also s water cooled so the motor rpm’s are not important for cooling
rjames
Oct 12 2023, 03:51 PM
True, but it's lugging the engine quite a bit if he's cruising at 2K RPM which would increase temps. Should still be 3K or over. Any increase in throttle at 2k RPMs while doing 50 MPH would induce some hesitation.
prrt1
Oct 13 2023, 01:40 PM
I know cutting wires is not a good idea. It is one of the two wires feeding the comb contacts in the TPS (wire 9 in my BMW) so it’s half of the “accelerator pump” now out of the circuit. The huge problem of severe bucking ( occurring when upshifting between 1st and 2nd) and the minor hiccups when cruising (that’s about 2-2.5K rpm) have both disappeared with the wire cut. Very little decrease in acceleration ability. I know it’s weird, but it works. I’ve tried adjusting the TPS (new PC board) per D-jetronic and that didn’t work. I figure most of the info the ECU needs to know about fueling the engine is coming from the MAP, the TPS is sort of a fine-tune, and the cut wire may be eroding my fuel mileage, but that isn’t a real concern. After a couple hundred miles or sooner I’ll pull the plugs and check for mixture problems.
