Hello
My heat exchangers (from 1.7 engine) are leaking air. The thin outer metal has holes where it is suppose to be bonded to the thick tubes carrying exhaust gasses. There is no exhaust gasses leaking into the heated air.
Is there a way of plugging these holes? Can silicon rubber withstand the heat? Is there a better substance to plug the hole?
Thank you.
