narino
Aug 27 2022, 11:08 AM
Hi all. I purchased a muffler from a 914world vendor and wanted to get a second or third opinion on the fit. I have a 1972 tail shifter and the muffler is hitting the cone at the end of the transmission even before tightening down the bolts. See image below for reference. Also, above the muffler you can see the GT muffler mount. With the bolts snug I still have about 1/4" gap between the bracket and muffler.
I've corrected the assembly of my engine mounts so I don't think that's causing the clearance issue; I'm using the 911 mounts with the concave washers. Is there anything else I'd need to check assembly wise? The vendor says it'll be fine to snug it down and have a divot in the muffler. Which I'm fine with. But my OCD kicked in and it's making me wonder if I don't have something else upstream put together incorrectly.
In the image below hopefully you can see cone touching the muffler in the back ground.
Is something off, or would tightening it down and having the transmission end touching the muffler be fine?
Thanks in advance!
Van B
Aug 27 2022, 11:30 AM
Do not force the fit. This is clearly an issue between fitment on a side shift vs tail shift.
narino
Aug 27 2022, 12:03 PM
@Van bShould I dimple the muffler for the clearance?
TheCabinetmaker
Aug 27 2022, 12:12 PM
It's it a bursch muffler?
narino
Aug 27 2022, 12:18 PM
@TheCabinetmaker It's from Ben's (mb911) SS muffler final production run last year.
johnhora
Aug 27 2022, 12:28 PM
this is one of the reasons the stock 2.0 and six mufflers are "banana" shaped to help clear the trans end/nose...on a 911 that's where the shift rod comes out..also the 911 mounts are a little shorter thank the 914 mounts pulling the whole assembly up at an angle making the muffler even closer...use the new 914 six mounts...I've found that the the GT muffler mount adds to the problem....the fix is to use longer mount studs with spacers to move it to the rear
what headers are you using
BeatNavy
Aug 27 2022, 12:34 PM
Heat exchangers must match up to appropriate exhaust (e.g., 1.7 HE's to 1.7 muffler) even if the HE's will basically fit any engine.
Are you sure that's a 1.7L muffler? It sure looks like my 2.0.
FWIW, do NOT put too much stress on those GT exhaust hangers. They will break and potentially cause you problems. Ask me how I know.
narino
Aug 27 2022, 12:43 PM
@johnhora It has 2.0 heatexchangers. Do they make spacers or is this a fab job? I'm assuming +-1/2" SS spacer with gaskets on both sides, yes?
@BeatNavy That is correct, they are 2.0. The car was originally a 1.7 then converted with a big bore kit.
johnhora
Aug 27 2022, 12:57 PM
Jorge...I was talking about a spacer on the GT mount...washers etc....I haven't seem any spacers for the header to muffler....you could fab
Really it's best to use the stock muffler mount and a muffler with the curve banana shape.
Had a customer once that allowed us to put a dimple in the muffler to clear...it was ugly but on the backside so not seen....crappy fix but he did not want to buy a new or different muffler
It's best to use stock parts if at all possible especially for a street car
Aug 27 2022, 01:08 PM
Did they convert to 2.0 exchangers as well? They look like they may be 1.7’s
narino
Aug 27 2022, 01:32 PM
@mepstein It has 2.0 heat exchangers. This is an old photo before i got rid of the modified exhaust hanger with tabs, attached below.
@johnhora Ahh, OK that makes sense for the GT bracket. The car will eventually get a custom headers from MSDS but for now, maybe a dent in the muffler will suffice. I agree, not a great fix, but as you say it's be on the back side. It already has a noticeable divot from when I first i stalled it then noticed it was touching. I guess the question is what tool to use, and can I harm any internals to the muffler?
maf914
Aug 27 2022, 03:11 PM
QUOTE(narino @ Aug 27 2022, 10:18 AM)
Before you dent your muffler, you may want to contact Ben and ask for his opinion. Ben has always been helpful with his products. 914/911 style mufflers have various baffles welded inside. You wouldn't want to break a weld or damage a baffle and alter the internal exhaust flow. It might not matter, but then again, it might.
Aug 27 2022, 03:40 PM
QUOTE(maf914 @ Aug 27 2022, 05:11 PM)
@MB911
narino
Aug 27 2022, 03:52 PM
@maf914 Thanks for the diagram! I had messaged him directly earlier. Maybe he'll respond here so it can help others in the future.
914werke
Aug 27 2022, 04:15 PM
Remember a tailshift equipped car never came with 2.0L (/4) HE's
Aug 27 2022, 05:06 PM
QUOTE(914werke @ Aug 27 2022, 06:15 PM)
Wow. Good point. Time to go side shift. - It’s worth it.
Mikey914
Aug 27 2022, 06:17 PM
Were the 2.0 exchangers really this much shorter?
What I'm getting at is the change to side shifter may not get the clearance needed.
narino
Aug 27 2022, 06:26 PM
QUOTE(mepstein @ Aug 27 2022, 04:06 PM)
Haha, I just need to get her back on the road right now. I've finally made my way through the mountain of 914 parts boxes and can see the light at the end. I can't bring myself to buy another large piece right now. I think I'd lose my mind.
narino
Aug 27 2022, 06:31 PM
QUOTE(Mikey914 @ Aug 27 2022, 05:17 PM)
Not sure. In a message to Ben earlier this year he says, he runs this exact muffler on his 911 with no issue. He seem to be fine with the transmission denting the muffler slightly. I reached out here to see if others who bought his muffler had similar issues.
Mark, do I remember correctly that you guys are building similar mufflers now? Or was that a fever dream from to much 914world scrolling?
Aug 27 2022, 06:32 PM
QUOTE(narino @ Aug 27 2022, 08:26 PM)
I think I'd lose my mind. - A requirement of 914 ownership.
sixnotfour
Aug 27 2022, 07:36 PM
Last run ......looks more likely to fit 1,71,8 headers,,, 911 mount behind the engine,,914-6 mufflers had longer header to muffler stubs... In Bens defense,,the muffler bus, got way to complicated..
Steve
Aug 27 2022, 08:16 PM
I used another flange with a gasket on each side as a spacer to move the muffler back. There is plenty of room with these mufflers to move them further back.
http://www.914world.com/bbs2/index.php?aut...ch&id=13080
narino
Aug 27 2022, 09:14 PM
QUOTE(Steve @ Aug 27 2022, 07:16 PM)
http://www.914world.com/bbs2/index.php?aut...ch&id=13080Thanks for the info. Did you fabricate a new flange, or cut them off old headers? If fabricated what material, CNC?
Mikey914
Aug 27 2022, 11:05 PM
QUOTE(narino @ Aug 27 2022, 05:31 PM)
Yes we are.
I’ll check to see if we have some 3/8” flanges. Let me know if you need a set $25+ actual shipping. Can send priority. 1st class only goes to 1lb.)
Mark
Steve
Aug 27 2022, 11:13 PM
QUOTE(narino @ Aug 27 2022, 08:14 PM)
Ben sold the flanges to me, when he was still making headers and mufflers.
mb911
Aug 28 2022, 07:13 AM
Jorge,
In the area you are having issues with you can indent the muffler if need be. It is clear the issue is the mismatch of tail shift, and 2.0 heat exchangers. That combo never existed. The 1.7 and the 1.8 heat exchangers moved the muffler in a different position.
Just an FYI my first new run of mufflers will be ready around October.
narino
Aug 28 2022, 10:53 AM
@mb911 . Thank you for the reply Ben. Any pointers on how to indent it? My current thoughts were to place the muffler on plywood covered with towels, to absorb blows and help reduce scratching on the exposed side, then hit with hammer and a drift. Thoughts?
Montreal914
Aug 28 2022, 11:03 AM
I would really look at a way to space it backward using the flanges, that is if there is room obviously, vs. creating permanent deformation to this nice muffler.
You might eventually want to convert your car to side shift where the spacers wouldn't be needed and you would still have a nice muffler, or who knows sell this part later on.
Denting it seems like a last resort solution in my book.
Other option is maybe sending it to Ben so he can properly cut and create a clearance recess.
Again, the flange ideas seems like the cleanest and pretty simple option if there is room.
Good luck!
narino
Aug 28 2022, 12:23 PM
@Mikey914 Mark I'll buy a pair of flanges from you if they are available. I think i have an extra pair of gaskets for the flange sandwich.
Thanks for all the help everyone!
mb911
Aug 28 2022, 12:41 PM
I have steel ones if you need flanges.
narino
Aug 28 2022, 12:56 PM
QUOTE(mb911 @ Aug 28 2022, 11:41 AM)
That'd be great. How how thick are yours and how much ?
mb911
Aug 28 2022, 02:06 PM
QUOTE(narino @ Aug 28 2022, 10:56 AM)
They are 3/8" and I know usps priority mail will be 9 dollars. So I could send a set for $20 total.
narino
Aug 28 2022, 02:46 PM
@mb911 OK good to know.
I'll wait to hear if
@Mikey914 has any left, since I've already told him I'd buy some from him. But I'm glad to know you have some available if he does not.
Thank you again!
Mikey914
Aug 28 2022, 03:15 PM
I can let you know Tomorrow afternoon as soon as I'm back in. I'll post up.
Mark
Cairo94507
Aug 29 2022, 06:48 AM
Please do not just dent that beautiful muffler; additional flanges is the best route.
VaccaRabite
Aug 29 2022, 07:19 AM
Added bonus - if you add flanges you can probably use a standard muffler hanger and not worry about the GT hanger. The standard boomerang hanger is better all around. Several of us have had issues with the Tbolts breaking and the muffler left hanging by the heads. The standard hanger is pretty bulletproof for supporting the muffler.
Zach
Mikey914
Aug 29 2022, 01:02 PM
I don't have any stainless available right now, but need to cut a few more up for another run, so I'll go a little heavier on the 2.0 flanges. I should have these ready in 7-10 days.
Mark
narino
Aug 29 2022, 02:55 PM
@Mikey914 sounds good. Thank you!
@VaccaRabite Good to know. Tha k fully i still have the correct old 2.0 hanger. Might just do that.
@Cairo94507 Thankfully I came to my senses, I will be doing the flange sandwich. Also, I need to see your car! I'm biased towards Irish Green. I'm in Culver City.
narino
Sep 10 2022, 09:23 PM
@Mikey914 just checking in. Any updates on the flanges?
Mikey914
Sep 10 2022, 10:43 PM
Just need to get some cut up. Should be about 10 days. Will be doing some 2.0 and 1.7
