QUOTE(Txbentleyboy @ Aug 30 2022, 09:05 AM)
Need a driver's side tail lamp assembly. My lens is ok so that's not necessary .
Thank you!
Will you be attending the "OCTEENERFEST" in September at Towsend , Tenn? I have three sets of tail light assemblies I'll be bringing. If not I can assemble a drivers side for you. There are two examples, early (that crack the black plastic housing over the low beam) and the later one that has a heat shield over the lamp and therefor don't heat the housing. The wiring is the same. You can PM me back and I can make one up anyway you want. AL
