QUOTE (spare time toys @ Aug 6 2005, 03:05 PM) |
what all do I lose when I swap one out? |
QUOTE (mharrison @ Aug 6 2005, 02:44 PM) |
If you don't do any heavy gaming, or heavy database queries then the difference in RPM speed probably won't be noticeable. Now that being said. With the SMART predictive failure message you're getting you need a new drive SOON. Add it in, run Norton Ghost (PM me to find out more about this) to duplicate your current drive to your new drive, pull the old one and you'll be ready to go. (Of course it probably won't be exactly that easy, but those are the basic steps.) |
QUOTE (rogergrubb @ Aug 6 2005, 08:11 PM) |
Norton Ghost requires that the same hardware be used because it makes a mirror image of EVERYTHING on your old HDD. Hidden files, system... This incudes how WindowZ sees your current hardware and hard drive. Certain hardware needs specific drivers and if the disk drive that you currently use doesn't work with the new one, your wasting time and money. If you can't but the identical hard drive and swap it out, then restore a Ghost image, then do as Andy suggests and get the stuff off that isn't replaceable. pics, mp3's, porno ... We use it at work regularly. Great program when using compatible hardware. |
