Need help troubleshooting which I think involves the turn signal relay (EP26).
Dropped the engine/trans to do some maintenance. Car runs fine after putting everything back except I noticed that the clicking from the signal relay intermittently goes on and off even after I release the ebrake. Btw, before dropping engine, the ebrake light and turn indicator light flashes when ebrake is engaged which I think is normal, and it does not activate the turn signal lights. But now, even when ebrake is disengaged I hear the relay intermittently clicking and the dash turn indicator also lights up in unison. Turn signals/lights work as before. So I suspect theres either a short or maybe a wire that I forgot to reconnect? Or perhaps the EP26 relay is going bad?
