TravisNeff
Aug 6 2005, 06:06 PM
Sure the pain in the ass factor of adjusting dwell and replacing points/condensors is just about worth the expense - but is there any other benefit to them (besides point bounce at high rpm)??
I have a dead CHT, so it's one of those while I am ordering things....
nsyr
Aug 6 2005, 06:25 PM
i just put in the crane xr700 in mine today and it does make it a better running engine. IMHO, ditch the points and convert, it's worth it.
tat2dphreak
Aug 6 2005, 06:26 PM
anything is better than points... but keep a spare set of points just in case... I use a compufire
Trekkor
Aug 6 2005, 06:27 PM
Do it!
Set and forget...Unless of course you install it wrong.
KT
McMark
Aug 6 2005, 06:55 PM
Electronic ignitions are less susceptable to distributor shaft wear. More smooth at higher RPM ranges. They boast of increased spark gap (ran my stock engine eith pertronix at 45 instead of 35). No maintenance.
Down side, they will burn out if you hook it up wrong, and they can die if the ignition is left on for long periods of time.
markb
Aug 6 2005, 07:11 PM
I had a problem with the points closing up quickly. We put a crane in it and I
it! I wouldn't go back. I do think I should carry a second dist in the trunk with a points setup, just in case, but then I was a boy sprout way back when.
Joe Bob
Aug 6 2005, 07:56 PM
Allison/Crane....best bet.
Pertonix....suckz.....
TravisNeff
Aug 6 2005, 09:59 PM
That's good enough for me! The crane unit is double the price over the pertronics and compufire, any chebby places offer it for less (summit or whatever)??
Joe Bob
Aug 6 2005, 10:03 PM
Yeah Summit and Pegasus are the best pricing....they sell them cheaper than what GPR and Pelican can get them for....
TravisNeff
Aug 6 2005, 10:17 PM
Is the part number CRN-700-0231, they only list one unit for the XR700 points replacement. $90.99 at Summit
brp914
Aug 6 2005, 10:41 PM
I put on a pertronix a few years ago. Simple install. No module, as opposed to others. If you get one with a module, dont mount on the engine. I went thru a couple of those years ago, back when they were Allison. The module cant handle the heat/vibration.
btw, you say your cht is bad. Had that happen, too. Isn't that weird? No moving parts. wtf?
TravisNeff
Aug 6 2005, 11:16 PM
No kidding, everytime I do a ohm test on it I get different results within a minute or so of each other. then finally it showed an open circuit.
Aaron Cox
Aug 6 2005, 11:22 PM
PERTRONIX - awesome kit. drop in. drive off.
Crane takes forever to setup.... is this on a carbed motor? if it is, weigh the 80 bucks toward a mallory unilite......
AA
TravisNeff
Aug 6 2005, 11:54 PM
nope, fool injected
Rand
Aug 7 2005, 12:30 AM
QUOTE |
Pertonix....suckz..... |
QUOTE |
PERTRONIX - awesome |
Ok, everything is perfectly clear now.
QUOTE |
anything is better than points |
Points aren't evil. They are easy to maintain, and they work just fine. Take care of them and they won't let you down.
But yes, a modern ET system is potentially better.
Glad that clears everything up.
And now for something completely different.
SLITS
Aug 7 2005, 08:38 AM
QUOTE (Aaron Cox @ Aug 6 2005, 10:22 PM) |
AA |
Only for budding engineers like Brit and Aaron.
rhodyguy
Aug 7 2005, 09:20 AM
wrong coil resistance may burn up the compufire. follow the instructions precicely. if you put one in and it cranks, and cranks, and cranks,... put the points back in.
k
Aaron Cox
Aug 7 2005, 09:52 AM
QUOTE (rhodyguy @ Aug 7 2005, 08:20 AM) |
k |
not hard to ohm your coil before you buy
rhodyguy
Aug 7 2005, 10:11 AM
right aaron. just a heads up. i failed to due so and burned up $70 worth of a module when i was putting the 73' together. i spent 3 days chasing a "no start/no spark". the solder melted out of the bottom was appearent when i pulled it. couldn't see it when it was installed.
k
Joe Bob
Aug 7 2005, 10:54 AM
QUOTE (rhodyguy @ Aug 7 2005, 08:11 AM) |
k |
Ahhhh, ya let the magic smoke out.....
rhodyguy
Aug 7 2005, 11:04 AM
majick smoke is as scarce as hen's teeth.
k
Rouser
Aug 8 2005, 02:29 PM
QUOTE (Rand @ Aug 7 2005, 02:30 AM) |
QUOTE | Pertonix....suckz..... |
QUOTE | PERTRONIX - awesome |
Ok, everything is perfectly clear now. |
The usual responses for the Pertronix unit.
I've installed them on two 914's, they're over 4 years old, and STILL running strong; no hiccups, no problems.
All I can say is, if you're happy running points, go for it. If you wanna pay more for a breakerless module, buy a Crane or Compu-Fire unit.
The Pertronix unit does the job just fine.
