QUOTE(Spoke @ Sep 18 2022, 09:31 AM)
As Steve said, the B light comes from the warning switch on the MC. You can test if the switch is tripped by disconnecting the wire on the switch to see if the light goes off.
As far as the brakes dragging, that is some other issue. You may want to lift each tire; press the brakes and rotate the wheels and see if one caliper is sticking all all are sticking. I think there's an adjustment between the MC and the brake pedal. Make sure there's some free play between pressing the brake and depressing the MC plunger.
The brakes are lightly applied due to incorrect adjustment of the MC pushrod.
They heat up from constant application then release when allowed to cool.
Ajust so there is some play between the brake pushrod and the master piston.
The fact that they free-up after cooling probably eliminates stuck calipers.....
probably.
