QUOTE(Brett W @ Sep 24 2022, 10:36 AM)
Now all of that said, the six makes a lot more sense in a race application....If you could stay in a small bore type class racing with MGs and 510s then the four will work reasonably well, but will require steady maintenance. Depending on the number of events you do, the engine will need to be opened for inspection frequently. Plan on bearing replacement on a regular basis.
I'll disagree and agree.
I intentionally left mine as a /4. I gave it a TON of thought, and really really really wanted to toss in a /6. But the costs of building a six are so much more, and there's really no end to the financial game on one of those (where is "enough"?)
But more importantly, as you point out, dropping in a /6 tosses you into the 911 group, where the wallets have no bottoms. It's really silly how much people spend on their 911s to go historics racing...and there's no real regs and if there is they're not enforced.
It was this last point that convinced me to stick with the 2L /4. I'd rather pay to play with the Fiata, Triumphs, and MGBs instead of the money (not that they're easy money spenders).
Of course, if you want to go faster and want the GLORIOUS sound of the /6 behind you, well, I salute you. I'd do it too, given the financial means.
So far I've not had any significant maintenance, although the build was (again, intentionally) a warmed-over build (2056, stock crank, rods, 86A cam, 9:1 compression). And given it only runs 2-3 times a year (I have another "real" SCCA race program) it should last for a while. I am giving serious thought to Microsquirting it though...that should asplode some heads (I'll make it look Weber-ish as much as possible).
GA
