QUOTE(Van B @ Sep 18 2022, 09:04 PM)
@nditiz1 do you mind schooling me on this part? Is it an aluminum version that fits up the same? I suddenly feel like I need this in my life lol!
I'm not nditiz1, but Yes, the A-Arms bolt up to the later 911 aluminum cross member, but you will also need the later 911 steering rack cover which does not fit very well. There are also special braces that are external to the cross member versus the 914 cross member has them welded on the cross member. Aluminum is lighter, but some say it flexes on the track. If your doing a six swap with a later engine, it does have the bolt holes for a fuel pump. It also makes it easier to add a hydraulic clutch or add a brace for your current master cylinder. You can also install a sway bar under the car versus in the car under the gas tank. If you don't need these mods, then don't waste your money or time.
