Was driving along and heard a strange noise when applying the brakes. Got home to check the break pads, which seem to be fine at 5mm, but did find that I could just slightly feel a wobble when yanking on the wheel while jacked up.
So I assume a bad bearing, but there seems to be some sort of small amount of oil on the hub itself. Brake lines are not leaking.
Does bearing grease break down to this consistency over time? Anyone seen this before?
